Bookmark
Subscribe
3185
ANSIBLE BACKUP ON CISCO
fmugambi
Hello Guys,
Below playbook is not working, kindly assist look into it and advise. Thanks.
Getting below error :-
What could I be doing wrong?
Hello, the ansible_network_os should be:
ansible_network_os= ios
16 Replies 16
Torbjørn
You need to remove the "host" parameter to your "DISPLAYING THE RUNNING-CONFIG" task.
The error message is saying that the parameter doesn't exist for the ios_command module. The "hosts" parameter is only allowed per play, not per task. If your goal is to run that task only for specific hosts, you can use a "when" statement to achieve this(see docs linked below).
You can read more about the ios_command module here, and these Ansible docs are also useful for controlling execution: Patterns: targeting hosts and groups  Conditionals based on variables
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
I tried this, but does not seem to work.
DO you have a sample playbook, i can compare to, or an external resource I can lookup.
does it depend on ansible version, did they change anything, cause am running ansible 2.14.9
getting local module not found.
What output are you getting?
fmugambi
theVPNbloke
Hello! 2 things. Remove the 'Hosts' line from your 'Display The Running-Config' task as you've already defined the scope of the target hosts in the second line 'hosts: Core_Switch'
Also have you defined the OS in your variables file?  -
ansible_network_os: ios
what is the OS variable, been using cisco.ios.ios, but says module unsupported.
Can you post the inventory file?
[Core_Switch]
CORE
[Core_Switch:vars]
#ansible_connection=ansible.netcommon.network_cli
ansible_network_os=cisco.ios.ios
ansible_user=xxx
ansible_password= yyyy
getting below: -
FAILED! => {"ansible_facts": {}, "changed": false, "failed_modules": {"ansible.legacy.ios_facts": {"failed": true, "invocation": {"module_args": {"available_network_resources": false, "gather_network_resources": null, "gather_subset": ["min"]}}, "msg": "ssh connection failed: Failed to authenticate public key: Access denied for 'keyboard interactive'. Authentication that can continue: publickey,keyboard-interactive,password"}}, "msg": "The following modules failed to execute: ansible.legacy.ios_facts\n"}
It seems that the password you have specified in your inventory is incorrect.
