Authentication failed on device 3 times. Failed to detect SSH version running on the device. PRIMARY-STARTUP config Fetch Operation failed for TFTP
gilvicfiserv
I have devices loaded but new devices keep getting this error "Authentication failed on device 3 times. Failed to detect SSH version running on the device. PRIMARY-STARTUP config Fetch Operation failed for TFTP" - which trying to get configurations. I am using LMS 3.0.1
I tried to TELNET on devices via Putty port 22 no good. Please help?
Name Version License Status Size CiscoWorks  Common Services 3.1.1 Licensed Not applicable  Campus  Manager 5.0.3 Purchased 1500  CiscoView 6.1.7 Licensed Not applicable  CiscoWorks  Assistant 1.0.1 Licensed Not applicable  Device  Fault Manager 3.0.3 Purchased 1500  Internetwork  Performance Monitor 4.0.1 Purchased 1500  Integration  Utility 1.7.1 Licensed Not applicable  LMS  Portal 1.0.1 Licensed Not applicable  Resource  Manager Essentials 4.1.1 Purchased 1500
7 Replies 7
Michel Hegeraat
Level 7
Level 7
Olny new devices have this problem?
Do the have the correct credentials then? If they are discovered they only have a read only community string set
The rest of the credentials must be added
Cheers
Michel
michel,
I re-checked after I posted this question to insure the SNMP RW was correct via another software and it was not...once I corrected it there and then in CW everything worked.
Thanks for your help.
Gilbert,
If you know which are the new devices and if they all have the same credentials then you can update them all in one go by selecteting them all and click edit credentials
if all your devices have the same credentials then you can select them all.
Cheers,
Michel.
Some items are still failing :
After doing a certification verification I am getting some devies to show me:
Showing 1-1 of 1 records
First pagePrevious page Go to page: of 1 pages Go to page entered in previous text fieldNext pageLast page
Device NameRead CommunityRead Write CommunitySNMPv3TelnetEnable by TelnetSSHEnable by SSHUpdated At
1.
R2020012_01
OKOKCredentials not verified.IncorrectDid Not TryFailed to connect.Failed to connect.Apr 2 2010 15:31:27
It will still not syc the Config Archive.
TELNET connection to R2020012_01 - Cause: Authentication failed on device 3 times. Failed to detect SSH version running on the device. TFTP: Failed to fetch config using TFTP.- Recieving error on this device as an expample of error file.
Device NameSysObjectIDModelDevice StatusInventory StatusInventory Last Updated TimeConfig StatusConfig Last Updated Time
1.R2020012_01.1.3.6.1.4.1.9.1.576Cisco 2811 Integrated Services RouterNormalSuccessJan 13 2011 10:43:49 ESTFailedJan 13 2011 10:37:24 EST
  Rows per page:
If you go in the Device and credentials part of common services you can try to export this device to a csv file
You then see what is configured as a telnet password and you can try yourself, best from the console of the LMS server, to telnet to this device
The only time I recall I had a telnet issue where the password was correct because someone changed the prompt on the device.
Cheers,
Michel
