Can't connect to web configuration for Firepower 1010
Raplus1942
I have a Firepower 1010 set up by following this guide here https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/fp1010/firepower-1010-gsg/ftd-fdm.html#id_82126
I plug my laptop into the management port, and I am able to ping the management interface ip, but actually connecting to the device manager ip on the browser times out.
Any idea why that would be happening?
Raplus1942
I got it working.  I had to configure https-access-list with the ip of my laptop.  Thank you all for the help.
12 Replies 12
Ping that good
Use different browser or change laptop' it can java or browser ver. Not match with firepower.
MHM
Well, I have tried Chrome, Edge, and Firefox
What IP you use for laptop ?
Can I see how you enter the http to access Firepower
MHM
The ip on the laptop was 10.10.10.21, the managment interface is 10.10.10.1.  I tried entering 10.10.10.1, https://10.10.10.1, and https://10.10.10.1:8305, because I saw that was the port of the interface.
You change IP of mgmt so you have access to console
Can I see
Show network
MHM
Debug http 255 <- can you debug the http when try to connect via FDM
MHM
It can be as @Giuseppe Larosa mention and you missing this step in start setup
Try use
>configure manager local
 Then check again
MHM
Hello @Raplus1942 ,
TCP 8305 should be for communication with an external FMC.
Are you sure you have configured the device for local mode ?
At the beginning of setup you need to specify if the device is managed by an FMC providing the IP address of the FMC or locally that is the option to make FDM to start.
From your document:
Manage the device locally? (yes/no) [yes]: yes
Hope to help
Giuseppe
Raplus1942
So I didn't actually set this up myself, but I just figured it was configured for local as we don't have an FMC.  I also ran these commands.
I entered the debug http 255 command, but I am not sure how to use this.
Raplus1942
Thanks so much for update me
Glad issue solve in end
Have a nice day
MHM
