Catalyst 3850-48T-E Switch Upgrade Path
mark.e.rodgers@navy.mil
Community Member
Hello, I'm want to upgrade a (Catalyst 3850-48T-E) Switch currently running 3.7.5E to  Fuji-16.9.5 MD.
1. Can I upgrade directly to  Fuji-16.9.5 MD ?
2. Are there any constraints ? (ex. ram)
2. Will my configuration change drastically ?
Thank you
Mark R.
Leo Laohoo
You can upgrade direct.
NOTE: The upgrade is from 3.X.X to 16.X.X so this means there will be a microcode upgrade and will take around 17 minutes.
balaji.bandi
yes you can upgrade directly.
follow strict rules :
1. take config backup out of the box
2. read the release notes understand the caveats and see if this any effect on your environment.
3. do upgrade in a maintenance window.
4. make sure you connect console cable capture all the logs, in case anything goes wrong you can have all logs to understand what is wrong.
5. prepare for rollback plan (copy the images to USB also - safe)
release and upgrade guide :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-9/release_notes/ol-16-9-3850.html#id_77758
BB
Leo Laohoo
