Cisco 3850switches NodewithbadMemory issue
mshahid1
How can we fix NodewithBadMemory problem please?
we got about 10 of those switches they have utilized over 70% of memory and constantly getting alarms on Network node manager monitoring tool.
Switches are operating normally and no performance issue. They got IOS version of 16.3.6.
This seems to be a problem, normally the memory should be between 40 to 50% but as it is 80% in your case this must be hitting a bug.
R2#show processes memory sorted allocated
Processor Pool Total: 396826796 Used: 52551940 Free: 344274856
I/O Pool Total: 33554432 Used: 4578400 Free: 28976032
Transient Pool Total: 16777216 Used: 10152 Free: 16767064
Try upgrading the device to the cisco recommended version.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
marce1000
 - Where did you find  this NodewithbadMemory outputted ; please post command given and resulting output ?
   M.
