05-17-2021 09:07 AM
I'm not sure if this is the right forum, but I'm looking for some good Cisco guidance documentation for intrusion detection systems. I was searching Cisco website, and I couldn't find something specific for 3925/3945 with securityk9 license.
Is IDS (intrusion detection systems) part of the IPS (intrusion prevention systems) ?
Any help will be really appreciated.
Thank you.
Solved! Go to Solution.
05-17-2021 10:12 AM
You may not find step by step document as you get latest one :
Look at below : (featrure document)
https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
05-17-2021 10:12 AM
