10-25-2022 08:46 AM - edited 10-25-2022 08:48 AM
Running into an error when attempting to troubleshoot a client Chromebook connection issue. We use a Cisco 5520 WLC with AIR-AP2802I-B-K9 AP's. When attempting to start a packet capture from the Cisco 5520 WLC, the WLC isn't able to communicate with the AP. The AP is functioning normally. Has anyone seem anything similar or able to sed a bit o light on what may be going on?
Solved! Go to Solution.
10-25-2022 10:34 AM
Thanks for the reply.
I don't believe that an ACL is in use for these devices. I don't see one in place.
I did see that KB, earlier am unable to use it atm as I'm unable to access the backend (CLI) at this time. Still working on figuring out the SSH credentials, so that I can try this & maybe a few other things from the backend of the AP's possibly. On this note, are you aware if there is a master/default SSH credential that would grant SSH access?
Thanks, George
10-25-2022 08:55 AM
what mode of deployment, as i remember some of the AP do not support that (trying to recall ?)
do you have any other model of AP ? that you can do packet capture?
what WLC code running ?
10-25-2022 10:20 AM
Thanks for the replay. I'm pretty new to this environment, so please ignore some of the questions.
what mode of deployment? > Can you clarify this a bit. Not sure what you mean by this? It's an enterprise environment with around 100 AP's (same model) between several buildings, although this issue is an intermittent wireless issue in a room between a specific client & AP. The issue is occuring in other spots of the building as well, just using this specific location for troubleshooting purposes.
What WLC code running? > Where can I verify this for you?
10-25-2022 09:20 AM
are you using an access list ? How many packets are you capturing ? Try a low number (use the default, 25, or something low like 30)
debug packet logging enable all 30
10-25-2022 10:34 AM
Thanks, George
