12-28-2010 12:48 PM
Yesterday i bought two of these switches from someone so i could study for my CCNA test. I checked them both and was able to connect and configure both over console. but now one of them will not let me connect over console. i hook up PUTTY/Hyperterminal and the first one works fine but the second one does not. I get no messages, nothing, but i can telnet into it. HELP!
12-30-2010 04:09 PM
Please post in the correct forum:
https://learningnetwork.cisco.com/community/certifications/ccna
12-30-2010 07:05 PM
This is the correct forum, that was irrellevent information. Im asking about a HARDWARE problem. Read the question before responding please.
12-30-2010 07:30 PM
Please post the config to the line cons 0.12-30-2010 07:33 PM
I reset the entire NVRAM and vlan's file over telnet. so its the standard configuration.
12-30-2010 07:41 PM
you might want to try different baud rates. if 9600 ( default ) is not working, 115200 usually works.
12-30-2010 07:42 PM
Thanks, il try that.
