10-02-2023 01:09 AM - edited 10-02-2023 01:10 AM
I have setup radius authentication for my IE-3200, so that if radius fails it will use local account for access.
When local account is used it goes touser level and you need to know enable password to go lvl15 and do changes, this is how I need it to be.
This is easy when taking ssh cli access, but if you log in via WEB gui is there an option to go enable level?
I cannot find that kind of option at WEB gui side.
Br.
Jari
Solved! Go to Solution.
10-02-2023 01:12 AM
Hello!
An option would be if you set the user at a priv 15. There is no enable mode on the GUI.
BR
10-02-2023 01:12 AM
Hello!
BR
10-02-2023 03:55 AM
Thanks for the reply, I thought that might be the only solution, or leave it so that WEB access is only user level.
Br. Jari
10-02-2023 04:00 AM
On the GUI you will not have that option either read or full access (this works different way compare to CLI access).
