Cisco IE-3200 and web gui, user right elevation?
j.leinonen
I have setup radius authentication for my IE-3200, so that if radius fails it will use local account for access.
When local account is used it goes touser level and you need to know enable password to go lvl15 and do changes, this is how I need it to be.
This is easy when taking ssh cli access, but if you log in via WEB gui is there an option to go enable level?
I cannot find that kind of option at WEB gui side.
Br.
Jari
DanielP211
Hello!
An option would be if you set the user at a priv 15. There is no enable mode on the GUI.
BR
****Kindly rate all useful posts*****
DanielP211
Hello!
BR
Thanks for the reply, I thought that might be the only solution, or leave it so that WEB access is only user level.
Br. Jari
balaji.bandi
On the GUI you will not have that option either read or full access (this works different way compare to CLI access).
BB
