04-20-2018 02:19 AM - edited 03-01-2019 06:32 PM
Hello gents,
Is there any way I can access to the ISR 4431 using GUI ? I mean full access not only monitoring status.
I need to make some VPN configurations. So i perfer to use GUI instead of CLI ( i know that this sounds like noob :) )
Thanks.
04-20-2018 12:12 PM
Do you have "ip https server" enabled in your device? You can enter the device from a PC (from where you can manage the device) using you web broswer to the https://X.X.X.X (IP Address)
---Do not forget to rate useful answers.---
Best Regards,
04-22-2018 08:34 PM
Hi Diana.
Thanks for your reply. But this method doesnt give me rights to make a changes at router 4431 for example implement VPN channels and even other configurations.
So i wonder may be there is any additionally software i can download to my PC and configure router via GUI .
04-23-2018 06:00 AM
I think you can do this using the Cisco Configuration Professional Application (you can review this link for your reference) https://microage.com/wp-content/uploads/2016/04/Cisco-4000-Family-Integrated-Services-Router-Data-Sheet.pdf If your device has a service contrac you can download it from Cisco.
Please do not forget to rate/mark useful post.-----
Best Regards,
11-30-2018 07:46 AM
Hello Diana,
I had tried CCP 2.7 with ISR 4331 few months back but that doesn't seems to work well, it didn't gave me any options to configure Unified Communications.
Is there any particular version and setting required for CCP to work with ISR 4K routers ?
thanks
04-25-2018 05:47 AM
Best Regards,
04-25-2018 07:57 PM
12-19-2018 08:49 PM - edited 12-19-2018 09:18 PM
Router# copy scp://1.2.3.4/isr4300-universalk9_npe.16.09.02.SPA.bin bootflash:/isr4300-universalk9_npe.16.09.02.SPA.bin
Router# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)# boot system bootflash:/isr4300-universalk9_npe.16.09.02.SPA.bin
Router(config)# ip http server
Router(config)# ip http secure-server
Router(config)# transport-map type persistent webui http-https-webui
Router(config-tmap)# server
Router(config-tmap)# secure-server
Router(config-tmap)# exit
Router(config)# transport type persistent webui input http-https-webui
Router(config)# username johnsmith priv 15 secret easytoguesspassword
end
wr mem
03-01-2019 07:21 AM - edited 03-01-2019 07:33 AM
I have a similar problem on a 4221 router except I cant access the webui at all. I have entered the configuration as previously described. I purchased the routers as a replacement for our cisco lab but they came configured with SD-WAN so I reformatted flash drive and copied the downgraded IOS-XE to V16.6.3 and copied the NIM firmware files and rebooted. Everything works fine except when I try to access webui from IE 11 it just says ERROR 404 page not found. In the details it states that the web site can be reached but the page is not found. Could I have removed some files from flash when I formatted it and if so how can I get them back.
TIA
