Cisco Prime Network Control System (NCS) problem
Yacinem
Frequent Visitor
Frequent Visitor
Hi all,
I want to reach out with my problem
I have a Cisco Prime NCS physical appliance, and I have the HDD problem decribed in the field notice below and I need to know if the described workaround is permanent or I should replace the HDD occasionally
https://www.cisco.com/c/en/us/support/docs/field-notices/636/fn63645.html
Thanks in advance
Mehdi
Mark Elsen
 - The idea is that if your device is affected, then the replacement  disks should work, permanent.
M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
M.
       Beauty and terror
      Just keep going
       No feeling is final
