Cisco vSwitch + VM Interaction
TheGoob
Hello
So I wanted to mess around with a virtual switch and assign some VM's to utilize it's access but this is all new to me and lab interaction is always a bit confusing with something new.
Are there any guides or sources where the process is explained in detail.
Such as, I configure a VM and I configure the vSwitch; how do I even get the VM's to see the vSwitch Interfaces.Definitely do not need it all put out in crayon for me but  a nice base would be pleasantly appreciated
2 Accepted Solutions
TheGoob
Got it to work! Geeze, forgot to create my NAT Access-list. wow.
I do not see NAT information here ? if you like to translated you need NAT ACL
https://www.balajibandi.com/?p=1796
BB
10 Replies 10
balaji.bandi
on the cisco switch side you can use Port-channel or trunk depends on configuration and allowed the VLAN required you looking to host on VMWARE.
VMWARE example guide explain :
https://knowledge.broadcom.com/external/article/311764/vlan-configuration-on-virtual-switches-p.html
there are several youtube guides to setup vswitch or dswitch(requred License).
start with this
https://www.youtube.com/watch?v=ZNHub_yRk-E
BB
govmlab #VMwareTutorial #LearnVMware #vmwarevsphere #virtualnetworking #vmwarenetworking #basicsofvirtualnetworking VMware Networking Tutorial | Virtual Networking Basics | VMware Tutorials for Beginners | Mastering VMware vSphere Networking For Personalized Learning: Join our learner's community
Not going to lie, that [the one you mentioned view first] was an excellent lesson and truly filled my head with understanding and concept. I have used esxi in a more "fun" scenario and did get my vms up and running and have enjoyed it but I had figured it out "successfully" but without the knowledge behind it, and this video definitely cleared it up.
With that being said, I struggle to see how to implement this in a Cisco vSwitch scenario in regards to "my" description as 'reverse interface' meaning normally the VM gets assigned a NIC/vmnic and it works.. But in this case I assign the vm [Cisco vswitch] a vnic to use backwards from that to assign to VM's. So, I assign the vSwitch 3 Interfaces. 1.) Management, 2.) Uplink to Router [Internet] 3.) The interface to use for the other Vm's on esxi.
My more refined confusion is this; Can I use ONE Physical Interface [assign it to a 2nd Switch on Esxi] and divide it to 3 port groups. 1 - management, isolated from LAN and internet. 2 - uplink to internet/router and isolated from management and LAN and 3 - LAN usage isolated from management and internet for VM's. When I say isolated, I refer to the esxi Switch, not the fact that within the Cisco vSwitch they will be able to communicate.
In this scenario, the Cisco vSwitch can ping 8.8.8.8 for internet [Using 2, Uplink] and any vm that is assigned to it's same port group [3, LAN]. And then when I create VM's, I use the Port Group 3, LAN, interface on the esxi Switch for their access to the Internet as well as other VM's on the same PG 3.
Or, did I miss it altogether still.
P.S I know this might possibly even be an esxi question for their forum but I really want this focus on Cisco vswitch being used on esxi, not just their vSwitch.
TheGoob
So I got it working but I do not got it working.
On esxi I created a [2nd] vswitch "8000LAN' which has no access to the main host switch but is alotted to connect VM's to the "inside" Interface of the 8000v VM.
In the 8000v I assign inside/lan interface 10.0.2.1 255.255.255.0 IP address, I create a dhcp server 10.0.2.0/24 and a default route[out] to 192.168.4.1 (thats the wan interface).
8000v can ping 8.8.8.8 and the VM 10.0.2.2.
VM can ping 10.0.2.1 but no 8.8.8.8
Clearly a routing issue but not sure where.
Outside interface is bridged ? send the screenshot of esxi interface config also show run from 8000v
make sure security setting accepted in esxi
check some guidance :
https://www.youtube.com/watch?v=EKpvpS9qxss
BB
Getting Started with a Cisco CSR 1000v Router Get Kevin's FREE SDN Mini-Course http://kwtrain.com/sdn ===================================================== ===================================================== In this video, you'll learn about Ciscos Cloud Service Router, the CSR 1000v. It's a ...
For now this is my setup.... As far as bridged, I see no bridge option on esxi!! Anyway, watching the video but here for now.
ip domain name eraseaoc.com
ip dhcp pool LAN
network 10.0.2.0 255.255.255.0
default-router 10.0.2.1
dns-server 8.8.8.8
lease 30
memory free low-watermark processor 225109
diagnostic bootup level minimal
interface GigabitEthernet1
ip dhcp client client-id ascii 9WQ9D77PZ0P
ip address 192.168.4.3 255.255.255.0
ip nat outside
negotiation auto
interface GigabitEthernet2
no ip address
negotiation auto
interface GigabitEthernet3
ip address 10.0.2.1 255.255.255.0
ip nat inside
negotiation auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet1
ip route 0.0.0.0 0.0.0.0 192.168.4.1
ip ssh bulk-mode 131072
BB
Correct, the running config was Prior to NAT/ACL, But I added it in.
so now the issue resolved with NAT ACL
BB
Yes! I seemed to have forgotten the obvious.
TheGoob
