Cisco Works Incorrect Community name
Hi all,
I use CW RME 3.5, CS2.2. Now there are two C3550-24, that respond for a polling with an Incorrect Community Name Trap. If I try to access these switches via CW it works... I can make my changes and apply them via snmp.
I compared a hardware (and software) report of these switches to other C3550-24 that works fine but all thats different seems to be the chassis version (and of course the hostname and IP ;-))...
any ideas?
Sebastian
7 Replies 7
nhabib
Level 9
Level 9
Are the Incorrect Community Name Traps sent when User Tracking discovery is run?
Hi nhabib,
yes i think so.
Sebastian
Hello Sebastian,
I suspect this could be related to bug id CSCea42364 somehow.
You might want to stop the CiscoWorks Daemon Manager, and add the following line to your ANIServer.properties:
UTGetVlansWithUserPorts=1
Re-start the CiscoWorks Daemon Manager and see if the issue is resolved.
i will try it out if u can tell me whre to find ANIServer.properties.... Sorry i'm new with CW.
Sebastian
On Windows it would be in CSCOpx\campus\etc\cwsi
On Solaris it would be in /opt/CSCOpx/campus/etc/cwsi
Make sure you make a backup of the original first
I found it but the Param is already set. Any other suggestions?
Sebastian
Hi Sebastian,
Did You resolve problem with incorrect community traps generated while CW2K runs user tracking??
Andrzej
