I've tried searching the community, but no luck finding a solution that works for me.
The problem is that I have 2 VTP domains, they both shows up in Topology, VTP Domains. But one of the doesn't show the VTP Transparent devices. The other does. Ciscoworks discover all the devices, bot VTP Domains consists of server/client and transparent. All switches in the VTP domains, are configured with the same values for snmp, user, tacacs and enable secrets. One switching environment has the domainname IDMZ and the other has YDMZ. YDMZ shows all devices under VTP Domain views in Topology, but IDMZ does not. I can see the devices under unconnected device view, and there I see them connected and looking good. The VTP are configured correctly, except transparent for those not showing up under VTP Domains for IDMZ.
Any ideas, what tp look for?
I'm running the latest version of Ciscoworks (4.0).
Br
Geir Sand-Strand
