Connect two SVI with Different Subnet
Faresnani
I have this topology with two SVI with Different Subnet, how to connect them together?
22 Replies 22
there's no ACL
the problem is that from Server (192.168.10.10) I can ping the GW (172.18.1.254) but I can not ping the SW-Client (172.18.1.252)
I understand the problem, just making suggestions as to what could be the issue.
You diagram shows 172.18.1.253 as the switch IP but you keep referring to 172.18.1.252, is that a typo ?
Can the router ping the switch and can the switches ping each other ?
Jon
thank you for your patience,
oh sorry its  typo
yes the router can ping both switches, but the switches cant ping each other
Can you post full confihguration of the router and both switches and indicate which port on each switch connects to the router.
Jon
in Client SW check if you enable or not ip routing.
I have the Router to make the Routing,
I want to manage and telnet the Client Sw from server-side
your PC VM connect is red so I think that VMware not work.
can you ping from PC to GW?
Replace servet with pc ping success
This may becuase defualt gw is missing when config server
Ping not success to svi
Sw need  ip default gateway x.x.x.x
