Correct procedure for default factory reset of Cisco C1111-4P ISR
I have recently acquired a Cisco C1111-4P integrated services router which was formerley the property of a company recently gone into administration.
I do not have the unit's logon profile (username and password) and have attempted to factory default reset via the reset button  but with no success.
Here's a transcript copy of the system output :-
User Access Verification
Username: Rom image verified correctly
System Bootstrap, Version 16.12(2r), RELEASE SOFTWARE
Copyright (c) 1994-2020 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: PowerOn
C1111-4P platform with 4194304 Kbytes of main memory
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
Reset button push detected
unable to open bootflash:golden.bin (14)
Located c1100-universalk9_ias.16.09.06.SPA.bin
Package header rev 3 structure detected
IsoSize = 419381248
Performing Integrity Check ...
Performing Signature Verification ...
RSA Signed RELEASE Image Signature Verification Successful
Image validated
cisco C1111-4P (1RU) processor with 1452661K/6147K bytes of memory.
Processor board ID FCZ2436904X
1 Virtual Ethernet interface
6 Gigabit Ethernet interfaces
4294966432 terminal lines
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
2863103K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
Router IOS Configuration Recovery is unsuccessful
%INIT: waited 0 seconds for NVRAM to be available
% Warning: use /31 mask on non point-to-point interface cautiously
This CLI will be deprecated soon, Please use new CLI 'ip http access-class ipv4
<1-99> | <access-list-name>'
WARNING: Command has been added to the configuration using a type 7 password. H
owever, type 7 passwords will soon be deprecated. Migrate to a supported passwor
d type
d type
d type
d type
%Log packet overrun, PC 0x1024E4C, format:
User:%s logged command:%s
*** You are responsible for all activity ***
*** Performed on this router ***
*** All config changes are logged ***
Username:
Can anybody please advise on what the problem is and how I go about a succesful factory default reset.
Thankyou.
23 Replies 23
yes sure we were suspecting always terminal emulators becaus break key not working.,
Glad you could able to resolve the issue..end is outcome is good, nice effort (we only suggest what information provided and inputs given).
BB
Hello Stephen,
Can you please tell me what do you mean by invoke a "pause" ?
by this you mean press "break" button from keyboard? or ctrl+c or something else?
when I tried ctrl +c i got to rommon 1 >
but after trying to change confreg or simply ignore configuration... the reset default never happens. the configuration stills there.
regards,
Hi, ive got the same issue. i can get into rommon but the c1111-8p doesn't want to accept any confreg registers i try. when i reboot it ither boots normally or loops back into rommon, is there a particular register in need to use for the c1111?  i cant even get to
Do you want to reset the router to the factory default
configuration and proceed y/n [n]:
if you resetting its boot as factory default
BB
Hi Thanks for your response, i cant even get past rommon or booting to the config i don't have access too.
Can you connect Console and post complete boot log,
check the steps for ROMMON:
Step 1
Connect to the ASA console port according to the instructions in Access the Appliance Console.
Step 2
Power off the ASA, then power it on.
Step 3
During startup, press the Escape key when you are prompted to enter ROMMON mode.
https://www.cisco.com/c/en/us/td/docs/security/asa/asa910/configuration/general/asa-910-general-config/admin-swconfig.html
BB
Thank you, as requested:
System Bootstrap, Version 16.9(1r), RELEASE SOFTWARE
Copyright (c) 1994-2018 by cisco Systems, Inc.
Current image running: Boot ROM0
C1111-8P platform with 4194304 Kbytes of main memory
Located packages.conf
IsoSize = 0
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated 5D28E437:D827EF6D:B7A0D9CB:E4558EA7:A12D7F34
expected 5D28E437:D827EF6D:B7A0D9CB:E4558EA7:A12D7F34
Image validated
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [], ISR Software (ARMV8EB_LINUX_IOSD-UCMK9-M), Version 16.10.3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Tue 17-Sep-19 20:14 by cedge-sw-dev
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
cisco C1111-8P (1RU) processor with 1453913K/6147K bytes of memory.
Processor board ID
10 Gigabit Ethernet interfaces
CRYPTO_PKI: setting trustpoint policy TP-self-signed-322306744 to use keypair TP-self-signed-322306744
Press RETURN to get started!
Honkkis
I managed to factory reset easily password recovery locked (reset button had no effect, except console telling it's disabled) ISR-1118-8P with console access using TeraTerm. No need to do any weird settings for terminal. Didn't even really need precise timing, just not hitting ctrl-C too many times, because if ctrl-C is hit too many times, it will skip factory reset prompt. Worked on second try.
Thanks for the reply, I will have another go at it. I've reset a few 890 routers but this unit is being difficult. I was just going to put it in the bin.
