EEM Hostname
hs08
I have successfully create EEM script to backup configuration to the TFTP but  for the file name i hardcode like this command
action 1.4 cli command "C9500-CR1"
Can we change the C9500-CR1 to getting value from the hostname automatically, so incase the hostname is changed so the filename also changed automatically.
Torbjørn
You can add an "action 1.4 info type routername" and then use the variable $_info_routername to reference the hostname.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
