Showing results forĀ
Search instead forĀ
Did you mean:Ā
EEM scripting help
Sunny5
I'm trying to have EEM script where I run the script manually and it display the output of the results in the session but for some reason I'm unable to do so. This is what I have so far
(config)#event manager applet TestCommand
(config-applet)# event none
(config-applet)# action 1.0 cli command "show version"
(config-applet)# action 2.0 puts "$_cli_result"
(config-applet)#end
When I do "event manager run TestCommand" it shows a blank output with no results.
Sunny5
i found my solution for this, i had to put single quotations around $_cli_result to get this to work
event none
action 1.0 cli command "enable"
action 2.0 cli command "show version"
action 3.0 puts '$_cli_result'
16 Replies 16
Georg Pauwen
it looks like you need to add the 'enable' command:
(config-applet)# action 1.0 cli command "enable"
(config-applet)# action 2.0 cli command "show version"
(config-applet)# action 3.0 puts "$_cli_result"
(config-applet)#end
this was my result when i ran it
debug event manager all
Share output of this
MHM
When I did this and ran the event manager run TestCommand, I didn't see any output for the debug
post the running configuration (sh run) of the device you have installed the EEM script on...
correct command is below
MHM
this was my result
here is what i have in my show run
I'm not sure why the $_cli_result command doesnt show
this is what I entered
Friend the correct command in yellow'
You need to config
Puts $_cli_result
Without any " inbetween
Check yellow command I share
MHM
sorry, are you asking to have it be like:
event none
action 3.0 puts $_cli_result
the action 3.0 line would get me a incomplete command
it work in my lab
do space between word puts and $_cli_result
MHM
yep, I have a space in between puts and the $_cli_result, I'm not sure why its being considered a incomplete command
Ok'
Use new event manager with new name
And use "" for puts command
And check result when you run it manually
MHM
this is what I've entered
And this was my result (same as previous)
odd indeed. I would delete all EEM scripts, reboot the router, and enter the script again...
