EEM Scripting using regexp to return all matches
kmd
Frequent Visitor
Frequent Visitor
I am working on a script in EEM that uses regexp to return results regarding 4g signal strength and GPS coordinates on a IR829 router.
This is the current script.
event manager applet test7
event none
action 010 cli command "enable"
action 020 cli command "show cellular 0 all | i RSRP|RSRQ|Current SNR|RSSI|Lat|Long"
action 030 regexp "([\_0-9\\-]+)" "$_cli_result" match result
action 040 file open test7.TXT flash:test7.TXT a+
action 050 file puts test7.TXT nonewline "$result"
action 060 file close test7.TXT
I am having issues with regexp as it is only returning the first match. For example the current output of the script only shows the current RSSI. I would like the script to return all values listed in the show cellular 0 command. See below:
Current Result:
-59
Wanted Result:
-59 -94 -16 2.4 38 23 20.5188 96 51 19.6884
Is it possible to get regexp to return all the matches or is there a better method to retrieve the results.
Any help would be greatly appreciated, thanks.
9 Replies 9
M02@rt37
Hello @kmd,
event none
action 030 set counter 0
action 040 foreach line "$_cli_result" {
    action 050 regexp "([\_0-9\\-]+)" "$line" match result
    action 060 file open test7.TXT flash:test7.TXT a+
    action 070 file puts test7.TXT nonewline "$result "
    action 080 file close test7.TXT
    action 090 incr counter
A counter is introduced to keep track of the number of matches found. The "foreach" loop iterates over each line in the output of  the  "show cellular 0 all | i RSRP|RSRQ|Current SNR|RSSI|Lat|Long" command. Inside the loop, the "regexp" action extracts the desired values from each line and appends them to the file "test7.TXT", separated by a space.
Best regards
kmd
Frequent Visitor
Frequent Visitor
Thanks for the response, M02@rt37
I have tried to put the script on the router but it doesn't like the "}" at the end of the script and comes back with "% Invalid input detected at '^' marker."
You don't specify the curly brackets at all - simply "action end" at the end of the loop block.
So:
action 100 end
 Command reference: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/eem/command/eem-cr-book/eem-cr-a1.html#wp3468947737
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
kmd
Frequent Visitor
Frequent Visitor
Hi @Rich R , I used the action 100 end and the script now runs. The problem is that it still only returns the first match. Is there something else not right in the script that is making it stop on the first match?
Output of script:
TEST-ROUTER#more test7.TXT
-47
See current script below:
event none
action 030 set counter "0"
action 040 foreach line "$_cli_result" "{"
action 070 file puts test7.TXT "$result "
action 090 increment counter
action 100 end
I think your problem there is using "{" as your line delimiter - there aren't even any of those in the result you're looking at so there will never be a match!
Looking at example at https://content.cisco.com/chapter.sjs?uri=/searchable/chapter/content/en/us/td/docs/ios-xml/ios/eem/configuration/15-mt/eem-15-mt-book/eem-policy-cli.html.xml
action 100 foreach int $poll_interfaces
action 101  cli command "en"
action 102  cli command "show int $int summ | beg ------"
action 103  foreach line $_cli_result "\n"
action 105  regexp ".*[0-9]+\s+[0-9]+\s+[0-9]+\s+[0-9]+\s+[0-9]+\s+([0-9]+)\s+.*" $line junk rxps
action 106   if $_regexp_result eq 1
action 107    if $rxps gt $max_rx_rate
action 108     syslog msg "Warning rx rate for $int is > than threshold. Current value is $rxps
 (threshold is $max_rx_rate)"
action 109    end
action 110   end
action 111  end
action 112 end
You should probably also be using the new-line delimiter for your end of line match?
I also don't think the counter variable is serving any purpose so can be removed altogether as you set to zero then increment on each loop but it never gets used anywhere.
kmd
Frequent Visitor
Frequent Visitor
Thanks for that @Rich R , I used your advice and have now revised the script again. It's working well but I am now running into an issue where I need multiple matches on a single line from the cli result.
Below is the result from the show command in the script.  And the result from the current script. In the latitude and longitude lines, there are three results in each. The current script is only returning the first result from each line (Shown in bold). I need the script to return the other values from longitude and latitude (underlined) I'm unsure on what to change in the script to also allow it to return multiple matches from a single line.
Additional help on this would be awesome, thanks.
Current RSSI = -56 dBm
Current RSRP = -87 dBm
Current RSRQ = -12 dB
Current SNR = 3.0 dB
Latitude: 38 Deg 23 Min 20.5188 Sec North
Longitude: 96 Deg 51 Min 19.6884 Sec North
Output from current script:
-56 -87 -12 3 38 96
Output that I am trying to achieve:
-56 -87 -12 3 38 23 20.5188 96 51 19.6884
Here is a copy of the current script.
event none
action 1 cli command "enable"
action 2 cli command "show cellular 0 all | i RSRP|RSRQ|Current SNR|RSSI|Lat|Long"
action 3 foreach line "$_cli_result" "\n"
action 3.1 regexp "([\_0-9\\-]+)" "$line" match result
action 3.2 file open test7.TXT flash:test7.TXT a+
action 3.3 file puts test7.TXT nonewline "$result "
action 3.4 file close test7.TXT
action 3.5 end
balaji.bandi
Can you post the output of below command :
show cellular 0 all
BB
kmd
Frequent Visitor
Frequent Visitor
The output from show cellular 0 all is super long and it has a lot of information I don't need.
This is the output from: show cellular 0 all | i RSRP|RSRQ|Current SNR|RSSI|Lat|Long
Latitude: 0 Deg 0 Min 0 Sec North
Longitude: 0 Deg 0 Min 0 Sec North
KhanAkhtar
Visitor
To retrieve multiple matches using regular expressions (regexp) in EEM scripting, you can modify your existing script to use a loop. Here's an updated version of the script that will capture all the desired values:
event none
action 030 regexp "(\\S+)" "$_cli_result" matchall result
action 050 foreach item in result
action 060 file puts test7.TXT nonewline "$item "
action 070 end
action 080 file puts test7.TXT ""
action 090 file close test7.TXT
In this updated script, the "regexp" command is modified to use (\\S+), which matches any non-whitespace character sequence. The "matchall" keyword is used to capture all the matches into the "result" variable.
The script then opens the file, enters a loop using "foreach" to iterate over each item in the "result" list, and writes each item to the file with a space delimiter. Finally, it adds a newline to separate each set of matches and closes the file.
With this modification, the script will capture and write all the desired values to the output file, separated by spaces.
Note: Make sure you have sufficient file system space available on your router to accommodate the output file. Adjust the file path and name if necessary.
