EEM to tftp copy code snippets to running config
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
04-09-2010 05:52 AM
is it possible to use EEM to copy code snippets from tftp server to the runnign config =- i'm trying to do this but no joy so far
event manager applet CHANGE-IGMP
event none
action 1.0 cli command "enable"
action 1.1 cli command "copy tftp://192.160.11/SNIPPET1.txt system:running.config" pattern "running.config"
action 1.2 exit 1
- Labels:
Network Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-09-2010 06:39 AM
It seems to me that it may simply need another line between actions 1.1 and 1.2 to respond to the prompt, something along the lines of:
action 1.2 cli command "y"
action 1.3 exit 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-09-2010 06:43 AM
hey that worked - thanks
I was trying to do that with the pattern response but it still didn't take it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-09-2010 07:04 AM
it works except that you have to use the pattern statement and put
"running-config"
in the command for the response to the copy
thank you for gettting me by that
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-09-2010 09:31 AM
yjdabear had the answer, but you really shouldn't be using "exit 1" in this policy. You should just remove that action unless you mean to tell the EEM server that the policy did not complete successfully.
Additionally, if you configure "file prompt quiet" in the running config, many file operations will not longer be interactive, and you will not have to use the pattern syntax.
