Embedded Event Manager cisco IOSXE 17 not triggering
valenciaa
Im not sure if this still work with the iosxe 17 but the eem applet is not triggering. Se below.
track 99 ip sla 99 reachability
ip sla 99
icmp-echo 10.10.10.1
frequency 5
ip sla schedule 99 life forever start-time now
event manager applet test
event syslog pattern "99 ip sla 99 reachability Up->Down"
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "int gi 1/0/1"
action 4.0 cli command "shut"
it looks like you have no spaces between 'Up' '->' 'Down' ?
Make sure your syslog pattern match looks like this:
event syslog pattern "99 ip sla 99 reachability Up -> Down" <-- spaces between Up --> Down
balaji.bandi
In addition what was suggested -- have you run manually is the EEM Script runs? what is the show logging output shows?
BB
