error logs in my L-3 Switch what is the problem how to sole
Philip D'Ath
What is the error message you are getting?
s.w _v.l.a.n -4- v t p _user_notification:v t p protocol user notification : version 1 device detected on g i 1/0/24  after grace period has ended
continuously getting in l-3 switch log
It sounds like you have a switch running VTP version 1 on Gi 1/0/24.  You could change that switch to using the same version as the switch reporting the error.
