02-27-2012 06:41 AM
hey, there,
It seems that i cannot find info on the requirements for the Flexible Netflow. Any link or info would be appreciated.
thanks,
han
02-27-2012 09:28 PM
Hi Han,
Flexible NetFlow or NetFlow v9 is supported on almost all Cisco platforms with atleast IOS 12.2(31)SB. Flexible NetFlow with major reporting options like Multicast, MPLS, IPv6, NBAR, etc requires atleast IOS 12.4(22)T. You can check the below link for details on IOS support:
Don Thomas Jacob
NOTE: Please rate posts and close questions if your query has been answered
02-28-2012 09:07 AM
Does IOS Ver 12.2.(33) SXI5 /6500 support this?
I was trying to configure but the command wasnt taken,
thanks,
Han
02-28-2012 11:34 PM
I guess you are using the ME6524. The specified IOS image does not seem to support Flexible NetFlow, but only NetFlow v5 or v9 as per Cisco Feature navigator. Please try the configuration as below for NetFlow export from your device:
mls netflow
mls nde sender version 7
mls aging long 64
mls aging normal 32
mls flow ip interface-full
mls nde interface
ip flow ingress layer2-switched vlan
ip flow export layer2-switched vlan
ip route-cache flow // This command has to be executed on all the L3/VLAN interfaces.
ip flow-export destination {hostname|ip_address} 9996
ip flow-export source {interface} // The interface through which NetFlow packets are exported. eg: Loopback0
ip flow-export version 5
ip flow-cache timeout active 1
ip flow-cache timeout inactive 15
snmp-server ifindex persist
Don Thomas Jacob
04-25-2013 04:45 AM
Hi Don,
can you tell me if for the support of flexible netflow in IOS 12.x with Sup 2T, an ip service image license is needed ?
I coulc not find the info about a possible requirement of ip service instead of ip base.
Jacky
04-26-2013 07:44 AM
You are right, there is very less info. From what I gathered from the feature navigator, you need an IP Services license or higher on your device for Flexible NetFlow support. Flexible NetFlow will work on an IP Base image if you have IOS 15.0(1)SY or higher.
Don Thomas Jacob
http://www.solarwinds.com/netflow-traffic-analyzer.aspx
NOTE: Please rate posts and close questions if you have found the answers helpful.
