How to make Alarm for interface Up/Down on Cisco Pi 1.3?
Dear all,
Could anyone please tell me how to monitor only some Uplink ports on C2960S, C3750X on Cisco PI 1.3?
I would like to receive the Alarm in case one of my critical ports is down.
Using syslog seem be inconvenient because it makes alarm for all ports.
6 Replies 6
Have you tried to configure an port group?
Perhaps this works.
Did you mean using the SNMP to monitor the group of ports?
I used the default interface health monitoring of Cisco PI 1.3, that included:
- Interface availability
- Interface input/output utilization/error/discard ...
However, it only show the availability percent of ports and port utilization,...
it did not make alarm when port down?
could you explain more details?
Yes, i meant that.
I've tried to create an port group and deploy template, but I had no success
I'll keep trying to find a way, if I get something, I'll let you know.
Actually, when you monitor Interface availability, it only provides Availability percent of ports (Ex: 25% uptime, 75% downtime)
If you want to monitor up/down status of ports, use IF-MIB with IfOperStatus and IfAdminStatus Objects.
However, for PI, it did not works.
Anyone help?
Hello Guys,
I have this problem here too, i need to monitor only trunk ports in my access switches, not all.
I receive some e-mails alarms because the up/down ports...
Anyone can help us?
Tks in advance!
MUQ_1899_
Can somebody confirm that the Interface Availability parameter in the default monitoring policy of WAN interfaces does not raise any alarms?
