10-06-2005 08:45 PM
In one of my routers configuration size is almost 30 K where my NVRAM size is only 32 K .While writing new configuration I am getting an error.
Please help
Saj
10-07-2005 02:14 AM
hi
can u revert what kinda router model you are using out there and what kinda error message you are getting over ther ?
also check out whether you got some unecessary files hanging out there and which can be deleted to free up the space..
regds
10-09-2005 09:42 AM
I had the same problem and the "service compress-config" global command fixed it.
