ISE Expired guest account purge not working
CCC3
I set up purge scheduling to clear expired guest accounts from day to day.
But at some point, the scheduling didn't work,
I manually clicked purge now, but it says start successfully, but it didn't actually purge.
The expired accounts are still piling up,
If you look at debug, purge event occurs
Deleted accounts are marked with '0'.
Please help me with this
version: 2.7 patch 6
balaji.bandi
The purge has been inoperative for about a month,
And the link you posted is purge to endpoint,
The current issue is purge for expired guest accounts.
Thank you.
