ISE redundancy failure
CCC3
We are currently trying to tie up redundancy using ISE version 3.2.
Also, at the customer's request, forward/reverse registration is not currently in DNS.
However, I set each other's IP and FQDN using the ip host command.
As far as I know, redundancy is tied up with just the ip host command.
If you attempt duplication, a failure log will appear as shown in the attached file below.
Are you aware of this issue?
ISE model is 3755.
7 Replies 7
balaji.bandi
is this config done on ISE side.
DNS is must - i do not believe baseline not changed much even the version increased :
3.2 guide -
Guidelines for Setting Up a Distributed Deployment
https://www.cisco.com/c/en/us/td/docs/security/ise/3-2/admin_guide/b_ise_admin_3_2/b_ISE_admin_32_deployment.html
BB
hello.
The IP HOST command is set in ISE.
They were set to face each other's IP/FQDN,
We are fully aware that DNS registration is essential.
However, as we have built several ISEs, we know that redundancy was possible with just an IP host.
But now an error has occurred, so I'm trying to check if it's a bug in version 3.2 or if there's another problem.
Let me be honest - i never tried that ( we generally use host entry to test in normal PC to punch DNS Entry before make any changes on the main DNS system,
as i take it was worked for you before version (not sure what version) and that is not working on ISE 3.2 (that take as defective as TAC case - can you open a TAC case to investigate for you ?)
On personal intrest when you using host entry ISE point to what DNS Server, does command level able to resolve  that DNS entry when you ping from CLI or do nslookup ?
BB
Make redundacy meaning use two PSN?
For which purpose you use ISE?
We are building ise to do tacacs.
It is still in the early stages of construction and redundancy is being tied up.
there is a bug in 3.2 where the DNS query fails when the hostname contains a dash. (-). To verify if you are hitting that bug, what if you use e.g.:
ISETACACS02.kt.com
hello.
The answer was late.
Currently, there is no two-way registration in DNS.
Only ip host is set.
Does the bug you reported apply equally to IP hosts?
Also, can you tell me the bug report ID?
