upgrading path for cisco ISR4431
noemifabbri
Hi everyone,
We have a cisco ISR4431 with version 16.6.7, and we want to upgrade it to 17.9.4a
Is there any suggested path or we can do it directly?
Noemi
balaji.bandi
check the ROMMON requirement - if the ROMMON is latest you can upgrade to the target version
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/release/xe-17-9/isr4k-rel-notes-xe-17-9.html
Also make sure you read the opened bugs and caveats before upgrade.,
BB
hi, our rommon version is 16.12(2r)
