Bookmark
Subscribe
2515
Issue with SSH remote access to switch.
shawn.koh
Hi, I am not able to SSH to my switch but telnet no problem.
I have already tried to zeroise the crypto key and re-generate again but problem still persists.
When I show log, this is the error msg.
241207: May 10 15:42:05.220: SSH2 0: RSA_sign: private key not found
241208: May 10 15:42:05.220: SSH2 0: signature creation failed, status -1
Anyone able to advise?
5 Replies 5
also try clearing the keys which eventually disable ssh depending on your device and regenerating the keys after.Also make sure to verify the regeneration of the key
show crypto key
what IOS version by the way?there's a possibility that you are hitting this bug here also
***Please rate all the useful posts***
-Prabath
I have already zeroize the key (it is same as clearing/removing the key).
Re-generated the key but still not working....
Not sure if restarting the switch will resolve the issue. We encountered this problem only after changing the hostname...
I came across this old thread here what it basically suggesting is to go back to your original name and then follow it in a sequence as in zeroized the key > Change host name > regenerate the key.
See if that helps before restarting
-Prabath
Supper... !!! it works.. Thank you..
damirich94
Hello!
I tried to create your situation in GNS.
What I made in R1.
conf t
int f0/0
no shut
ip add 10.10.10.10 255.255.255.0
ip domain-name example.com
crypto key generate rsa
1024
ip ssh version 2
username admin secret 123
line vty 0 4
login local
transport input ssh
do write
What I made in R2.
conf t
int f0/0
no shut
ip add 10.10.10.20 255.255.255.0
do write
I tried to connect via SSH from R2 to R1 = OK.
After that I changed hostname of router R1 to R44 and rebooted router.
Next I tried to connect via SSH again and everything is OK.
Problem didn't appear.
Am I wrong somewhere?
