12-30-2010 12:56 AM
I have enabled auto mode and manually included but when I run a data collection some devices don't take part in the process. When I click in show included devices I can see 19 devices in Not Managed state. What is this? How can I fix it?
I attach ani.log file
12-30-2010 03:57 PM
Verify Auto Managed is enabled in Campus Manager:
01-03-2011 01:06 AM
Yes, Auto Managed is enabled
01-17-2011 08:34 AM
a TAC case was logged on this issue:
the debugging in the ani.log showed that the devices were not managed because they wre arleady part of a management cluster:
com.cisco.nm.ani.server.frontend.EvalTerminateAndRemoveException: Removing
duplicate cluster member device ....
we have toggled off cluster discovery by setting the below value in the ANISERVER.PROPERTIES and restarting the ANIServer process, after that all devices were managed correctly:
Discovery.Cluster=OFF
02-27-2012 01:11 AM
hi, I have changed it too off but after running discovery again it has not changed, still there are 9 missing devices !!!
04-12-2012 11:53 PM
Finally I found the reason why my devices are in included devices ;
it was very simple because I have too many same hostnames, I changed the hostname to be unique and it still have those devices in the included !!! after every changing we you to reinitialize the ANI server with the apropriate command (
NMSROOT\bin\perl.exe NMSROOT\bin\dbRestoreOrig.pl dsn=ani dmprefix=ANI
and then start the discovery .
It is finished
