MIB: ifOutDiscards
uwe.dreier
a customer is using the following MIB to monitor a WAN interface
RFC1213-MIB:ifOutDiscards
OID  1.3.6.1.2.1.2.2.1.19
and reports lot of errors to me ...
If I check on the the router I cannot see many output drops on the WAN interface
Could it be that we are facing any kind of IOS bug here as we already know that the 7304 IOS versions are not always teh best :-(
Cisco IOS Software, 7300 Software (C7300-IS-M), Version 12.2(31)SB15, RELEASE SOFTWARE (fc2)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 26-Mar-09 09:37 by vpernank
ROM: System Bootstrap, Version 12.2(20060713:011624) [balam-EXODUS_WS_MIRZAM_ROMMON_060713 101], DEVELOPMENT SOFTWARE
pchi1036 uptime is 48 weeks, 4 days, 4 hours, 26 minutes
Uptime for this control processor is 48 weeks, 4 days, 4 hours, 26 minutes
System restarted at 06:30:48 UTC Sun Jan 24 2010
System image file is "disk0:c7300-is-mz.122-31.SB15"
cisco 7300 (NSE150) processor (revision F) with 2031615K/65536K bytes of memory.
Processor board ID SCA0737009P
SB-1 CPU at 800Mhz, Implementation 0x401, Rev 0.2, 512KB L2 Cache
4 slot midplane, Version 67.49
GigabitEthernet0 is up, line protocol is up
  Hardware is Pinnacle GE, address is 000c.ceeb.3600 (bia 000c.ceeb.3600)
  Description: --- Carrier = AT&T Offer = OPT-E-MAN Silver p2pt
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 13/255, rxload 15/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full Duplex, 1000Mbps, 1000BaseLX, Auto-negotiation, media type is LX
  output flow-control is XON, input flow-control is unsupported
  Last input 00:00:00, output never, output hang never
  Last clearing of "show interface" counters 1w0d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 37688
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  30 second input rate 61721000 bits/sec, 10654 packets/sec
  30 second output rate 52934000 bits/sec, 9593 packets/sec
     9396223055 packets input, 7054439734060 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     8050498041 packets output, 5453913001688 bytes, 0 underruns
many thx for any answers
cheers
Uwe
yjdabear
Are you saying the ifOutDiscards value is much larger than the "Total output drops: 37688" seen in "show interface"? If so, one possibility is since ifOutDiscards is a 32-bit number, and you say there're a "lot of errors", so between the time you snmpwalk ifOutDiscards and you run "show interface", it has rolled over (reset to 0, then start incrementing again).
