network topology map Cisco Prime Infrastructure
toskie9999
Hi just want to inquire if it is possible to create a network topology map on cisco prime infrastructure's dashboard that will display both wired and wireless devices or do we need another cisco product to accomplish it.
AFROJ AHMAD
Topology service is not supported in PI 2.0 yet , however it is in the road map.
for the feature support and comparison , you can check the below link:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/guide_c07-729089.html
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
17 Replies 17
AFROJ AHMAD
Thanks-
Afroz
Hi Afroj, so the topology service is supported now? Or not yet?
Ong
Hi Ong,
I think not yet but I will check and update the thread as and when I got to know about this...
Thanks Afroj!
It's projected for PI 2.1 but has not reached Customer Commit (CC) status last I heard.
Hi Marvin, the topology service is supported in Prime LMS right?
Yes Wei , it is supported in Prime LMS ..
I see.. I never use it before and straight using Prime Infrastructure. And am wondering why Prime Infrastructure does not support topology service which I think is highly useful
yes , you are right . It is an Important feature which is missing at the moement . As Marvin said "
It's projected for PI 2.1 but has not reached Customer Commit (CC) status last I heard'
Hope we will have it in PI 2.1
Thanks-
Afroz
Guys ,
Good News , you will see Topology services in PI 2.2     :-)
Thanks-
Afroz
At long last, Prime Infrastructure 2.2 was released yesterday (17 December 2014) and now includes the Topology map feature:
"Cisco Prime Infrastructure provides a visual map that allows you to view the physical network topology, including the network devices and the links that connect them. The topology maps have indicators that show the current alarm status of network devices and links. By using the network topology maps, you can easily monitor your network by viewing alarms and viewing the interconnection between the devices." (Link)
I'm migrating a system now and will open a new thread with first impressions.
Do we have an approximative release date for the lan topology service ?
Topology services is not available in PI 2.1. The feature "might be" in PI 2.2, which is targeted to be released by the end of this year (around Nov but it is tentative).
As i highlighted "might be" ,because every release say "future plan" .
Thanks-
Afroz
Marvin Rhoads
I see a presentation at Cisco Live Milan previewed the upcoming Topology features.
See slides 115-121 in BRKNMS-3102 - Advanced Prime Infrastructure 2.x Features (2014 Milan), available on www.ciscolive.com
