New Cisco Prime 3.9 DNS resolving problems
jasonmeyer
Trying to get prime to communicate with tools.cisco.com for smart licensing, but it always fails. In the shell when ever it use
nslookup tools.cisco.com it adds the domain-name...ie tools.cisco.com.domain-name which causes it to fail. If I remove domain-name I get another resolver error. Ping to local gateway, and IP address of tools.cisco.com all work.
balaji.bandi
Look at the some bug and workaround :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvx06532?rfs=iqvred
if this is not case kindly show us the config and problem.
worth check this thread :
https://community.cisco.com/t5/network-management/cisco-prime-infrastructure-dns-problem/td-p/3371012
BB
balaji.bandi
BB
Disabling DNSSEC did the trick.
