Prime Infrastructure 1.2
nafrasiyabov
Hello Fellas,
We bought Cisco Prime Infrastructure 1.2 appliance. The application seems to be pre-installed. I have gone through setup process. But I cannot connect/open web interface(https://PI-ip-address). What could be the problem ?
10 Replies 10
patoberli
Can you ping the server? That should work.
Otherwise, it takes some 3-10 minutes for the server to completely start up (at least for the virtual appliance).
Can you ssh to the ip address?
Patrick
Yes, I can login via ssh to the server. It is not a virtual apliance. I can login to Helth monitor interface which is on port 8082. But https connection doesn't work. When I check listening ports on server I cannot find https-443 port on that list:
show ports
Process : rpc.statd (4254)
     tcp: 0.0.0.0:620
     udp: 0.0.0.0:614, 0.0.0.0:617
Process : portmap (4173)
     tcp: 0.0.0.0:111
     udp: 0.0.0.0:111
Process : Decap_main (6242)
     tcp: 127.0.0.1:2000
     udp: 0.0.0.0:514, 0.0.0.0:162
Process : Xvfb (6040)
     tcp: 0.0.0.0:6100, :::6100
Process : sam_daemon (7227)
     tcp: 0.0.0.0:2012
     udp: 127.0.0.1:17989
Process : java (5039)
     tcp: :::5001, :::8082
Process : java (6042)
     tcp: :::20555
Process : java (7086)
     tcp: :::20556, :::1199, :::20848, :::1299
     udp: :::54496
Process : java (5913)
     tcp: :::20558, :::21
Process : java (5979)
     tcp: :::20559
     udp: :::69, :::29001, :::29002, :::29003, :::29004, :::29005
Process : tnslsnr (5088)
     tcp: :::1522
Process : sshd (4724)
     tcp: :::22
Process : ntpd (4705)
     udp: 10.13.203.101:123, 127.0.0.1:123, 0.0.0.0:123, fe80::3640:b5ff:fed:123, ::1:123, :::123
Process : ora_pmon_wcs (5181)
     udp: ::1:25531
That's good.
Try:
ncs status
That should give an output like (after some waiting time):
cpi1/admin# ncs status
Health Monitor Server is running.
Reporting Server is running
Ftp Server is Disabled
Database server is running
Tftp Server is running
Matlab Server is running
NMS Server is running.
SAM Daemon is running ...
DA Daemon is running ...
Syslog Daemon is running ...
status
cpi1/admin
Now if it's not running, type:
ncs start
It should either start then, or produce an error why it couldn't start.
Here is the output:
ncs status
Health Monitor is running, with an error.
failed to start NCS on startup Health Monitor
Ftp Server is running
NMS Server is stopped.
status
And a 'ncs start' output?
Also with 'show logging' can you see tons of logfile.
You could open a second ssh connection, issue 'show logging system tail' and then on the first ssh connection type the 'ncs start'
But I can't really help any deeper here, you probably need to open a tac case. Or maybe reset the appliance and start fresh.
I have stopped and started the system. The result is the same. "show logging system tail" doesn't give much information. How can I reset the appliance ?
I'm not sure, but check out the installation guide, it could be written in there.
Where you able to ever get your NCS appliance up and running?
Hi Rob,
No, I am not. I have removed NCS application and will install it again.
Hi Rob
Do you use the hardware appliance or the virtual appliance?
If you use the virtual one, do NOT modify the hardware requirements. That could also cause issues, like the appliance not starting up.
