Prime LMS 4.2.1 Dashboard problem
Dawit Zeru
I've a Dashboard problem in LMS 4.2.1
I can't create or delete dashboards in my Username I've try to delete the username and creating it again and it didn't solve the problem,
the same error message appears
here is the error message
can someone advise me how to handle this problem
thanks
Nael Mohammad
Level 5
Level 5
In LMS 4.1, this was a bug with "CSCtq29347"  which is URL redirection issues.
Try the following steps:
1. Stop the daemon manager.
2. After stop the daemon manager, back-up the portal.properties and portal.script from the location NMSROOT\MDC\tomcat\webapps\cwportal\db\
3. Copy the portal.properties and portal.script file from the location NMSROOT\MDC\tomcat\webapps\cwportal\db\orig\ and replace it to NMSROOT\MDC\tomcat\webapps\cwportal\db\
4. Then start the daemon manager and check.
After resetting the Portal database the custom created dashboards won't be available.  Don't create an  Embedded/URL dashboard as a first dashboard. Create  a portlet dashboard first and afterwards create any type(Embedded/URL/portlet) of the dashboard.
Nael Mohammad
Level 5
Level 5
Hi Nael,
Sorry for the late response,
it help.
