06-26-2012 06:02 AM
Hi All,
on a 4.2.1 LMS installation, switch ports that have port security configured and there happens a violation, thus going into errdisable mode, DO NOT show any alarms on the dashboard. Therefore we don't see any errdisabled ports listed.
Has anyone seen this before?
Thank you,
George
06-28-2012 05:00 AM
what is your schedule for faulty discovery ?
are the device managed ?
06-28-2012 10:17 AM
Fault discovery uses the defaults. On another installation for another customer this works fine. Additionally, this is a trap sent by the device to the LMS so no need for fault discovery. Also, the debugs for the device site show that the meesages are being generated and sent to the LMS over the SNMP.
The device is a 4507R+E-SUP7L.
Any more thoughts?
06-28-2012 05:41 AM
It should generally work. I have an LMS 4.2.1 installation that definitely shows errrdisable ports on the main dashboard (and relevant submenus).
06-28-2012 10:18 AM
Yes I know, on another installation for another customer this works fine.
Any more suggestions?
06-29-2012 12:43 AM
update device packages
might be new for c4500
did you give reload a try ?
/etc/init.d/dmgtd stop
/etc/init.d/dmgtd start
if its on windows, you have several other possible options as to why your UDP/162 trap gets dropped ?
06-29-2012 01:01 AM
Device packages already up to date.
Reload already done.
LMS and device on the same mgmt VLAN, no ACLs and/or firewall/AV whatsoever...
11-22-2012 12:27 PM
Do you have the correct snmp trap configured on your 4507? Something like
snmp-server enable traps errdisable
regards,
Craig
11-23-2012 02:55 AM
Hi Craig,
thanks for replying.
Yes I have the trap configured. Any more suggestions?
Cheers.
