Prime upgrade 3.10.2 to 3.10.4
Moudar
Version 3.10.4 is now installed but the login screen is showing 3.10.undefined like this:
What is now installed is this:
When trying to install PI 3.10.4 Update 02 System Patch, it says:
What I am trying to install is PI 3.10.4 Update 02, so why it says you need to have that to install the same, I am confused!
Here you can see what is already installed:
Any ideas!
7 Replies 7
marce1000
 - What output do you have from the CLI command  : show version
 M.
show version
Cisco Application Deployment Engine OS Release: 4.1
ADE-OS Build Version: 4.1.0.001
ADE-OS System Architecture: x86_64
Copyright (c) 2009-2022 by Cisco Systems, Inc.
All rights reserved.
Hostname: prime-10
Version information of installed applications
Cisco Prime Infrastructure
Version : 3.10.2 [FIPS not Enabled]
Build : 3.10.0.1050.90
Installed Patches: PI 3.10.2 Maintenance Release
Critical Fixes:
        PI 3.10.2 System Patch ( 1.0.5 )
        PI 3.10.4 Maintenance Release ( 2.0.0 )
        PI 3.10.4 System Patch ( 1.0.0 )
 - Is  the particular view (login screen on browser) ; consistent among  different browsers ?
 M.
Have tested Chrome, Firefox and Edge, all same
 - You may try to isolate the code in the login page (source) that extracts the version and replay manually ; but it could indicate a corrupt installation and or for utmost safety , re-install might be needed ,
 M.
b.tyler
Was there a resolution to the Version: 3.10 .undefined issue?  I've upgraded 4 Prime servers to 3.10.4 and 3 of them are showing  .undefined
I didn't find a solution, but it started working on all browsers after a while.
