12-22-2015 07:01 AM
Hello word,
After having installed a Cisco Prime 2.2 and added several WLC, my customer just wants a read only managing from Prime. So, when I added WLC I provided SNMP v3 RO and no telnet/SSH user/password/enable.
The problem is my customer would like to manage Guest Users from Prime, I obviously some kind of write privilege is needed. Changing SNMP from RO to RW would be enough? Or maybe I have to add a SSH/telnet user/password/enable to manage it? Or maybe I will be both SNMP RW and telnet/SSH?
Thank you very much!
David
Solved! Go to Solution.
12-29-2015 08:31 AM
Hi David,
most likely you would need RW and ssh\telnet as well ,however it depends on what kind of operations your guest user will have access to.
Thanks-
Afroz
***Ratings Encourages Contributors ***
12-29-2015 08:31 AM
Hi David,
Thanks-
Afroz
01-04-2016 12:49 AM
Hi Afroj,
Thank you very much. Mostly I'd like to manage WLC in order to add or remove guest users, what do you think?
01-04-2016 03:45 AM
you would need "RW" in most cases, for you also "RW" should be fine.
Thanks-
Afroz
01-04-2016 04:16 AM
Thank you very much! I will try with these privileges :-)
01-12-2016 02:13 AM
We changed SNMP from RO to RW and we verified that guest users are manageable from Prime without any enable user.
