Network Management
Labels
Hello Cisco Community Team,I would like to seek expert guidance regarding a network design concern we currently have.Current Network Scenario:We have a firewall connected to multiple ISPs handling internet security and routing.Downstream of the firew...
My main question is it possible to create an RSPan where source ports are location on sw1 and sw2 with the destination port to a remote collector also resides on sw 2. And two what would the commands be?what i was thinking was this:SW1 :vlan 999 remo...
egr1985 by Level 1
  • 164 Views
  • 4 replies
I need some help guys! So we are tasked to figure out DHCP as a school work, and the first part is the DHCP standard. So here comes the next part, as you can see in Networks 1 and 2, they are connected and have DHCP service at Server 1. So the task t...
nixb by Level 1
  • 956 Views
  • 13 replies
I am trying to connect to GUI interface of WLC but it is continuously showing "Server Reset Connection". I configured the management interface of WLC with an IP 192.168.10.10 and PC connecting with the WLC with an IP 192.168.10.11. The PC and WLC are...
