ā01-16-2024 12:58 AM
We have a Cisco Prime 3.10 VM running in a VMware ESXi, 7.0.3 and NFS3 environment. We have to move it to a new environment with VMware ESXi, 7.0.3 and VMFS6.
What is the best way to do this and why? To move the VM or reinstall Prime in the new environment?
Solved! Go to Solution.
ā01-16-2024 01:32 AM
I suggest to build new VM on new Environment as fresh copy and take old PI backup and restore on New PI and check all working.
If the IP is changed you may re-sync with devices - if you looking to use same IP then shutdown old PI and check on new PI all working as expected - before delete old VM of PI.
Note : always keep backup copy outside - until all working on new one do not delete that backup.
When you move - some time you may not get all assurance data to new Prime.
