Removing Device Pack file from Prime Infrastructure
Silvia3
Hello.
On the Software Update page of Prime there is one Pack which i can not install or delete because it is already included in another installation i did before. Now this pack stays on the page and i am not able to remove it.
Does anybody know where these files are stored in the CLI or how i can remove it from there?
Thanks.
Hello M.
i found it by myself. If the pack is not installed, like in my case, you can delete the file here:
S.
marce1000
 - In essence not possible and or checkout this thread : https://community.cisco.com/t5/network-management/cisco-prime-3-1-how-to-remove-device-pack-7/td-p/3016808
 M.
Hello M.
S.
andres-perea
if the file state in Use is Yes you can´t dele the file,   how change the state to No
If they are in use, you can not delete them. They are needed if in us is Yes and need to stay on the device.
