router 4331 rommon mode
younisalnour
hi,
how can i enter to rommon mode in this router
thanks in advance
balaji.bandi
Good and glad to know all working as expected, let us know any further assistance  required, if not can we make this as resolved.
BB
8 Replies 8
balaji.bandi
younisalnour
can you be more specific i've been search all the day with no result
thanks for your reply
appreciate that
balaji.bandi
here is the steps :
1. power off the device
2. connect console cable. (Configure the terminal to operate at 9600 baud, 8 data bits, no parity, and 1 stop bit (9600 8N1).
3. Power on the device, as soon as you see console output, use break key  or cntr + c
you see ROMMON1 >
not sure what you want after that your choice.
BB
Leo Laohoo
If @balaji.bandi instruction does not work then format the bootflash: and reboot the router.
actually i want to rest the password for the router
how can i reach the bootflash: ?
balaji.bandi
if you want to reset the password, if the password option not disabled.
below URL (this was advise in the past post) still valid.
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/troubleshooting/guide/isr4400trbl/isr4400trbl02.html
BB
younisalnour
Thanks for your help it was a problem in the router when i replaced it ,able to get log in to the rommon mode
balaji.bandi
BB
