09-05-2022 08:32 PM
hi, Greetings.
I have a request here. I have a vlan that has wired users and wifi users. However, i would like to use a separate vlan for wi-fi users. Can you assist me how to do that?
Solved! Go to Solution.
09-05-2022 08:49 PM
if you have both type of users in same VLAN, you can separate them to different VLANs. if you have WLC, you can configure new VLAN mapped to wireless SSID and use same VLAN in switches to transfer traffic between networks. if you have single AP, configure SSID VLAN to new VLAN and for network switches create the new VLAN to transfer traffic.
09-05-2022 09:02 PM
Gateway MAC option means this Device will have the ability to access any hosts in the Local Network.
After finishing the settings above, WiFi clients connected to the Guest SSID which enables the Isolate LAN option can only access the Internet and cannot access the other local computers even they are in the same LAN network.
09-07-2022 02:11 AM
if they use same VLAN then separate the subnet range in DHCP for wire and wireless
if you want totally separate by using different VLAN, then you need to check the WLC VLAN-WLAN mapping use different vlan for wireless
09-05-2022 08:49 PM
09-05-2022 08:54 PM
Hi, Kasun Bandara, thank you for responding. can you advise where to do what and how to do it?
09-05-2022 09:02 PM
09-05-2022 09:32 PM
hi, Thank you. this is however, not an issue with guest and lan users. both users are in the company-I just want to separate them. How can i do that?
09-07-2022 02:11 AM
09-05-2022 10:36 PM
do you have a diagram of your network? how WLC connected and switches with APs? also models. with that details we can give some hints to configure
09-05-2022 10:48 PM
I have 7 Unifi APs with WLC connected to the core SWX with VLAN 36. All wired lans use Vlan 36 too. I wish to use a different vlan for the Wifi Users.
09-06-2022 11:55 PM
WLC is Unifi-connected to Cisco switch.
