Setting the TFTP destination for RME Archive Sync
jmszkandera
We are attempting to do an Archive Sync from RME in LMS 3.2.
LMS is installed on a Solaris device with multiple VNICs (let's define VNIC1 IP as 1.1.1.1 and VNIC2 IP as 10.0.0.1). The network which has managed devices on it is connected to NIC 2 in the 10.0.0.0 range. We use VNIC 1 to access LMS. There is no routing between 1.1.1.1 and 10.0.0.0.
Now, I understand that when RME attempts to sync a switch, it starts and SSH session into the device and triggers a "copy flash: tftp:" command. This is apparent from the debug logs from RME.
These TFTP based retrievals are failing because RME is setting the TFTP destination to the IP from VNIC 1 (in our case, to 1.1.1.1). Is there any way to force RME to use another IP address for the TFTP destination?
Thank you.
- JMS
Martin Ermel
you should be able to workaround this by going to
     RME > Administration > System Preferences > RME Device Attribute > Add Natted RME IP Address
and enter 10.0.0.1 as the Natted IP address
Martin Ermel
Thanks very much. I'll try that and see if it works out.
Regards.
- JMS
That did the trick.
