Subinterface SNMP issue
Hello All
I have upgraded ASR-1002x ios version from asr1002x-universalk9.03.16.09.S.155-3.S9-ext.SPA.bin to asr1002x-universalk9.17.033.SPA.bin .
No problem but very strange thing occured. I have subinterfaces in configuration  like Gi 0/0/2.501 .... After IOS-XE  upgrade, my network management tools like Solarwinds and Cacti could not able to create subinterface bandwidth values on graph.
İ can see subinterface names and graphs but can not able o write its bandwidht on graph.
yajimene
Looking at the version you upgraded to, this could be related to:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvy25845
As stated on the bug, the problem is not seen on 17.3.2
- Yaros
8 Replies 8
Mark Elsen
 - Could you snmpwalk the device(interfaces)  again and or look for the intended oid's -> sometimes the oid's can get changed (slightly). You may then need to adapt your snmp manager settings in order  to use the correct oid's again for the intended sub-interfaces.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
balaji.bandi
Do you have traffic on that interface, can you post show interface gi 0/0/2.501
on solarwinds, go to device, list resources or option poll now again check.
is this only issue with sub-interface- rest of the interface able to produce what you looking ?
BB
yes i have traffic on that subinterface
this is only issue about subinterface . My regular Layer-3  interface graph is ok .
i have this output ;
XXX#sh snmp mib ifmib traps
ifDescr ifindex TrapStatus
GigabitEthernet0/0/2.501 24 disabled
Loopback777 19 enabled
Tunnel27 21 enabled
GigabitEthernet0/0/3.3968 37 disabled
GigabitEthernet0/0/4 5 enabled
Loopback66 18 enabled
GigabitEthernet0/0/3.3220 31 disabled
Tunnel27 21 enabled
i have seen this before, but in solarwinds i can see the traffic on sub interface.
example as below :
BB
yajimene
- Yaros
Hello Guys Thanks for all answers
After downgrading to version asr1002x-universalk9.16.12.05.SPA.bin ( Gibraltar Version ) traffic rates created.on graphs  This was a bug.
