Is it possible to configure EEM to execute an action whenever any one of multiple syslog messages matches a pattern? I would like to know if it is possible to write syslog patterns using an "OR" condition.
The content you are looking for has been archived. View related content below.
I’m looking for some guidance and shared experience from the community regarding improving network performance in a small business environment.We are using a standard business router setup with multiple devices connected throughout the day (laptops, ...
Please release my ip Your current IP is 95.164.67.146.It attached to an email i don't know which one. Probably randomly generated.
Hello,we've monitored our devices via CheckMK and the Meraki special agent and recently updated our Meraki MS390 and C9300L switches to IOS-XE 17.15.5.Since the update we are not able to monitor/get the interfaces, status, utilization, or anything be...
Hello everyone,I'm currently continuing my Extended ACL lab, and I have a question.How can I allow a specific IP address within a VLAN 30 (IP address: 192.168.30.10) to access another VLAN without allowing that other VLAN to access the specific IP in...
Hi,Has anyone tried to design network , hardware , software redundancy between 2 Core Switches and 3 access switches in standalone in separate network rack with no possibility of stacking.
We are not using camera and sensors in our environment. Organization->Firmware upgrades->Schedule upgrades-Any status (critical).I am getting all are related to camera and Sensors. I dont wish to see this details in the path Organization->Firmware up...
Hello Guys,is it possible to get Cisco configuration and release document for IOSXR25.2.2 ? will it not be available in internet ? Could anyone please help here ?
SSH Access Segmentation Challenge on ISR4300/IOS-XE 17.12.4a Platform Hardware: ISR4331, ISR4321 (ISR4300 series) Software: IOS-XE 17.12.04a Objective Implement SSH access with two different security policies based on authentication method: Public ke...
I'm replacing two 2901 routers with newer 4331 routers both running IOS-XE 17.12.07b. The two routers are at two different sites with two different internet service providers. On both routers, I have the "ip address dhcp" on my WAN interface, ...
Hello, if you want to use the dohost command in guestshell, you need to have the "ip http server" enabled. however, i want my script to enable this if it is not configured (for security reasons, it is always disabled in our standard config). now, l...
help with erasure of accidentally created cisco learning network account
Trying to figure this one out, I have 2 WAN and 1 backup WAN connection. I want 2 WANs always active for specific Routing and load balancing. I want my backup connection to be just that in case the Main WANS go offline. I am using port 3 and port 4 f...
I have posted a similar issue before but I failed to give all of the needed details. In short, I have ATAs that work in one client office but not another. I have an IT company that says a firewall cannot cause any errors on an ata. Everywhere I l...
We’re excited to announce that Role-Based Access Control (RBAC) Custom Roles is now generally available (GA) in the Cisco Meraki dashboard.Building on RBAC Foundations, Custom Roles gives you and administrators greater flexibility to align dashboard ...
| Subject | Author | Posted |
| 08-22-2026 06:24 AM | ||
| 07-26-2026 02:25 AM | ||
| 07-19-2026 06:14 AM | ||
| 07-18-2026 12:58 AM | ||
| 05-19-2026 02:32 AM |
