VTY Session Timeout
avilt
Level 7
Level 7
I have defined VTY 0 15 timeout, my SSH session is on MGMT (out of band) interface and vty timeout is not working. How do I enable it for MGMT as well?
kubn2
Level 7
Level 7
Hey,
In general configuration use:
ip ssh time-out XXX
instead of XXX put time in seconds, you can additionally use:
ip ssh authentication-retries 5
to limit tries to 5 or any other number that you like.
I have the following commands but no ssh session never gets disconnected.
SW01#show running-config | include ssh
ip ssh maxstartups 10
ip ssh time-out 30
ip ssh logging events
ip ssh version 2
Also defined following command on MGMT but no effect.
SW01(config-if)#timeout absolute 60
transport input ssh
Georg Pauwen
not sure if I missed something, but how did you configure the VTY timeout ?
line vty 0 4
exec-timeout 1
will disconnect your VTY session after 1 minute of inactivity (regardless of whether you are connected through SSH or Telnet)...
