ā10-11-2020 10:41 PM
So I have the following situation:
2 buildings with 2 networks of 240AC access points in mesh configuration. Each building and mesh is connected to a different internet provider, the APs connected through a SG-110-24 switch. The 2 networks are overlapping so I could make a single mesh.
The question is: would it be possible to do that having in view that there are 2 different Internet providers? The AP mesh is smart enough to go through 2 different internet access points to get it's data? The reason I'm asking is that I have the possibility to put an authentication server in only one of the buildings, so it would be easier with just one mesh.
Thank you!
ā10-12-2020 12:20 AM
Going out the Internet is more of your end router or FW task. So you can achieve with PBR, Regarding authentication, you can have 1 for all.
if still has an issue, can you draw a small diagram for us to understand better?
ā10-12-2020 01:02 AM
ā10-13-2020 11:40 AM
thank you, This is on high level how is your AP connecting (do you have WLC ?) they directly connected to SG110?
ā10-13-2020 12:00 PM - edited ā10-13-2020 12:08 PM
No WLC - directly in the switch and the switch directly to the Internet Provider. The switch from building number 1 has 9 240AP's and the switch for building number 2 has 15 240 AP's. Around 500 clients to authenticate.
