ShaunGreen
Dear All,
I'd like to run the following past you to see if anyone is able to shed more light on the subject.
We've noticed that when a show running-config is issued against a non L type 9300 (although it's running 16.9.5) the ACL's are in an output format that I would normally expect, I.e.
Name of ACL and then then the permit/deny rules (but no line numbering).
When the same command (show running-config) is issued against a 9300 L model (running 16.12.4) the output has the line numbers to each rule.
I would expect this if a show ip access-list command was run, but not with show running-config.
Is anyone able to share any more information on why there is a difference?
Is there anyway to configure the L model to display the output without the line numbering?
Simon.
2 Comments
balaji.bandi
To get to the point and understand the issue - if this only Line numbers causing the issue.
can you please post both the output to understand.
16.12.X is the latest and have more features added as part of improvements always Cisco Does.
ShaunGreen
Sure, hope this helps.
show running config with 9300 L
Show running-config with 9300 NON L
